現在的時間是 01/21/2020 12:06 am
發表新文章 回覆主題  [ 7 篇文章 ]
文章發表於 : 04/29/2005 8:10 am
文章: 1297
http://darwinports.opendarwin.org/archives.php?id=22
DarwinPorts 1.0
28 Apr 2005, 4:11 PM
After more than two years in the making, we are pleased to announce the immediate availability of DarwinPorts 1.0 in both tar.bz2 and tar.gz formats. Checksums are available here.
As well as being the first numbered version of the popular ports system for Mac OS X and other platforms, 1.0 is expected to bring many changes and new features for users of the current CVS release. It is highly recommended that all DarwinPorts users move to this version, paying close attention to the steps detailed in the README.
We would like to thank the countless contributors, past and present, without whom this milestone could not have been accomplished.
Reference:
Notes on DarwinPorts 1.0
[digdog dig];
最後由 digdog 於 04/30/2005 9:57 am 編輯,總共編輯了 1 次。
文章發表於 : 04/29/2005 11:20 am
文章: 1297
原始碼(擇一下載)不到 500KB︰
http://darwinports.opendarwin.org/downl ... .0.tar.bz2
http://darwinports.opendarwin.org/downl ... 1.0.tar.gz
下載後解開,執行:
代碼:
% ./configure; make; sudo make install
大約三十秒(:badgrin:)就可以完成安裝。安裝完畢之後,即可使用。
如欲取得最新的 portfiles 資訊:
代碼:
% sudo port sync
如欲更新 DarwinPorts 版本:
代碼:
% sudo port selfupdate
使用說明︰
DarwinPorts Guide
#osxchat 的 DarwinPorts 中文介紹
[digdog dig];
文章發表於 : 04/30/2005 9:54 am
文章: 1297
http://packages.opendarwin.org/DarwinPorts-1.0.dmg
.DMG 格式推出,直接點兩下即可安裝,連 port sync 都先幫你做好了。
[digdog dig];
文章發表於 : 04/30/2005 11:05 am
文章: 8060
digdog 寫:
cool
文章發表於 : 04/30/2005 11:19 am
註冊時間: 10/03/2001 1:01 am
文章: 1990
來自: 大馬/星洲
some port cannot compile, i.e. dlcompat
個人網頁
文章發表於 : 04/30/2005 11:53 am
文章: 960
來自: 邪教組織 #osxchat
oeyvind 寫:
bug report should be welcomed.
void
sched_init(void){
文章發表於 : 04/30/2005 12:05 pm
文章: 1297
oeyvind 寫:
就跟你說沒事不要裝 fortune,bad luck 了吧?
代碼:
% man 3 dlopen
引言回覆:
AUTHORS
Mac OS X 10.3 incorporated the dlcompat package written by Jorge Acereda
<jacereda@users.sourceforge.net> and Peter O'Gorman <ogor-
man@users.sourceforge.net>.
In Mac OS X 10.4, dlopen was rewritten to be a native part of dyld.
[digdog dig];
