現在的時間是 07/08/2020 1:32 pm
發表新文章 回覆主題  [ 3 篇文章 ]
文章發表於 : 03/26/2003 6:20 am
註冊時間: 07/04/2001 1:01 am
文章: 147
來自: Nowhere to Nowhere
sorry, this question might not be really relative to os x but unix:
1. in bbedit i edit a line like:
<tab><tab><tab>this is a test
when i move the cursor, the location of cursor would jump to each <tab>'s position
2. in gvim i edit the same line:
<tab><tab><tab>this is another test
save it, and open in bbedit. it seems <tab> is replaced by spaces, and cursor is moved space by space but not by <tab>
3. however, if i open the file edited by bbedit in gvim, the <tab> shows the correct behavior
4. in my .vimrc i setup
set ts=4 "tabstop"
set sw=4 "shiftwidth"
that's all
5. how do i setup the <tab> in gvim so the <tab> is not replaced by space
6. hope my description is clear enough to be understood :lol:
thanks
Fortune favors the bold.
- Virgil (70 BC - 19 BC)
文章發表於 : 03/27/2003 8:10 am
文章: 147
自問自答:
set noet
其實我並不是很懂expand tab 與 suppress tab 之間的不同
有人能解釋一下嗎?
好像版上的人用emacs比較多 :D
文章發表於 : 03/27/2003 10:33 am
文章: 1297
expand tab 是把 tab expands 成 blanks
代碼:
expand -4 tabfile > blankfile
suppress tab 應該就是相反吧?
[digdog dig];
